heat management and hi idle info
last week i had my 1k service done and while there had them enable the idle heat management system, just to let you know you can turn it on and off with or without the enjine running as long as you are not moving anf just at idle, so if you get stuck in traffic you can turn it on with out shutting the bike down. also some one posted about a service bulletion to recaslabrate the ecm to stay power up for ten seconds after the bike is shut off. i dont know if the dealer did this to me bike but now after i shut it down about ten to twelve seconds later my tach and speedo \\; needle drop below 0 mph and then return back to normal. dont know if this has anything to do with this or not. maybe someone can check if thiers does the same thing. ride safe[sm=biker2.gif]
robertj74
04-04-2009 10:21 AM
