diy tire change
Old 06-26-2008, 05:19 PM
tailgater's Avatar
tailgater
tailgater is offline
Default diy tire change
Bought my new rear tire. Took the tire and rim off of my ultra. I couldn't break the bead on the tire to rim. Do any of you riders change your own tires? How do you break the bead without damage to the rim? Please help.
Old 06-26-2008, 05:27 PM
relli's Avatar
relli
relli is offline
Default RE: diy tire change
take em to your local automotive shop and ask them to do it . 10 second job. if they have a rim clamp machine they can easily change them too.then add the dyna beads-inflate and RIDE!
Old 06-26-2008, 05:53 PM
G wizz's Avatar
G wizz
G wizz is offline
&nbsp\\;
&nbsp\\;I bought a Mo-mar motorcycle tire changer - It has paid for itself since I bought it two years ago. Works great, fast, and easy.
As the name implys, it won't mar the rims, as no metal touches to wheel.
&nbsp\\;
&nbsp\\;G wizz
Old 06-26-2008, 05:59 PM
cookiemech's Avatar
cookiemech
cookiemech is offline
Well, I have a Coats 220 tire machine in my garage, with a No-Mar conversion and No-Mar bead breaker. The other bead breaker I use sometimes is an old J. C. Whitney bead breaker meant for car tires, and it works great. You just need to be sure that the rim is supported so that the brake rotor(s) can't touch the floor. You're not likely to break the bead by just jumping on it or by hand.
Old 06-26-2008, 07:14 PM
blubagger's Avatar
blubagger
blubagger is offline
put the tire in vise on the workbench and squeeze and squeeze some more[8D]
Old 06-26-2008, 08:25 PM
tailgater's Avatar
tailgater
Been there, done that. The vise squeezes both sides at the same time and the tire sides will come together before the bead breaks. Guess I will look at the Harbor Freight machine and also talk to my local tire shop.&nbsp\\; I would like to do the whole thing myself for the money savings and I could do it at my convenience.
[align=left] [/align]
Old 06-27-2008, 12:42 PM
honestbob's Avatar
honestbob
honestbob is offline
J+P cycles has a bead breaker for around 50 bucks I got one 10 years ago and I have used it a bunch. Works like a giant modified C clamp. that and a couple of tire irons and tubless tires take just a few minutes to change. (once the wheel is off the bike)
Old 06-27-2008, 12:59 PM
Roadhog02's Avatar
Roadhog02
Roadhog02 is offline
+1 for the J P Cycle's item,&nbsp\\;it is only $36.00. I have used it a few times and it works great.&nbsp\\;It also&nbsp\\;helps when you are mounting the new tire also.
Old 06-27-2008, 01:01 PM
garyhendley's Avatar
garyhendley
garyhendley is offline
i do most of my own maintance but changing tires is not 1 of them hats off to you guys !!
Old 06-27-2008, 01:07 PM
0204665J's Avatar
0204665J
0204665J is offline
For a 1 hour labor charge to take it off, re-place, balance and re-mount it is worth the cost on that one....I do most of my own work, but this one seems worth it...
Quick Reply: diy tire change
