diy tire change
RE: diy tire change
It all depends on whether you actually ENJOY working on your bike. If you don't, then it's silly to try to mount your own tires. But I look at the two alternatives:
1) Spend a couple of leisurely hours in my climate-controlled garage, listening to satellite radio, smoking a pipe, and there's no one there but me and the machinery. The job is done right\\; if something's damaged, I know exactly who to blame. I always have a set of tires on the shelf, ready to go for when the time comes.
2) Call and try to schedule a tire change at a dealer or independent. If I'm lucky, then they'd actually do it when they say they will. That would undoubtedly be at their convenience, not mine. So I'd better predict exactly when I need the tire and not run it down to 2/32" first.
Stand around with my thumb in my a$$ while they get to my job. Pay a bunch of money. Hope they balanced it right. Take it home and still have all the work of installing the wheel (or, of course, pay more money and have them do the whole works. Then I can hope that they tension the belt correctly.)
Easy call for me.
Easy call for me.
RE: diy tire change
I need to start doing my own too. \\; Just bought a rear tire from local indy for a good price. \\; But, the pimple-faced "tech" didn't even know how to take the bags off! \\; So, I was helping him out with a few pointers, when out comes the owner. \\; Chases me out of the shop, condemns hes salesman for quoting me the low price on the R&\\;R, humiliates the poor kid, right in front of me, then fumbles through the install while I watch. \\; Of course, he fought with me the whole time for watching, while he's fighting with my bike. \\; Here's a quote: We don't have a 36mm socket. \\; So I say: 1 7/17 will work too. \\; He sez: I've got 1 1/2"...that's close enough. \\; I had to re-do all his work when I got home, including re-attaching the slip-on that was hanging out of the head pipe. \\; I got what I paid for, I guess, but luckily, it was a cheap lesson.
RE: diy tire change
ORIGINAL: ken thompson
You. \\;\\\\\\; Just had the rear done today at the dealer. \\;\\\\\\; $100 labor. \\;\\\\\\; Well worth it.
RE: diy tire change
ORIGINAL: tailgater
Been there, done that. The vise squeezes both sides at the same time and the tire sides will come together before the bead breaks. Guess I will look at the Harbor Freight machine and also talk to my local tire shop. \\;\\\\\\; I would like to do the whole thing myself for the money savings and I could do it at my convenience.
[align=left] [/align]
For those that don't think it's worth it, consider this. I balance the wheel first. The heavy spot is rarely the valve stem so after I mount the tire I usually need fewer weights to balance the tire &\\; wheel. I don't scratch my own rims or the rims of friends I change tires for. I don't screw up the bikes I work on. I replace my valve stems with metal stems. I know what I'm riding on, both product &\\; workmanship.
RE: diy tire change
Thanks to you and roadhog2 I ordered the j&\\;p bead breaker. They also have nylon rim proctors for 6 bucks so I got a couple of them. No more waiting at the dealers while someone does my work for me. I will also use the dyno beads for balancing. Thanks for the info.
RE: diy tire change
ok seems like there arent ANYold school mechs here so heres how to do it. lay a 2 by 4 on the grond lay rim on top of board . lay 2nd 2 by 4 on top by rim and slowly drive a vehicle onto the board and voila! the rim bead pops!! \\; \\; thats how its done on the old school days. i have done so many rims this way i can do it in \\; my sleep
RE: diy tire change
Here's another 2x4 old school technique. \\; Take a 4-5 foot long board to serve as a lever. \\; Place one end of it under your car for an anchor. \\; With the wheel beside the car, place a short 2x4 block on the bead and press down with \\;your 2x4 lever. \\; Don't laughit works! \\; It hasn't failed me yet.
