Anyone ever use aviation fuel in their Harley?
RE: Anyone ever use aviation fuel in their Harley?
I'd run it in a heartbeat! Just be SURE your mufflers don't have cats in them and add a little Marvel Mystery Oil to it so you have a little upper cylinder lube. \\;Avgas tends to have less lube than conventional fuel. I used to run it in my old street rod with Hilborn injection and 12.5/1 compression ratio! \\; Never had the first problem related to the fuel. The mechanical FI was a whole different story!
Big debate on this when leaded gas went away. \\; I had 71 Mach 1 and debate was with out the lead would you have to harden the valve seats. \\; There was never any definitive proof either way, so I just left it alone and it worked fine.
I AM ASSUMING IT IS 100LL.
YES IT RUNS BETTER, AND THE LEAD DEPENDS WHAT YEAR YOUR BIKE IS.
I USE TO USE IT IN MY 73 SPORTSTER.
HOLD ON WHEN YOU TWIST THE THROTTLE
YES HE CAN RECYCLE IT IF YOU DO THE SIMPLE WATER TESTS., NOT A BIG DEAL BUT IF IT'S FREE HELL YEAH
PLUS I HAVE BEEN IN \\;AVIATION FOR 30 YRS
Goldenbear777
01-16-2013 04:26 PM
