Anyone ever use aviation fuel in their Harley?
RE: Anyone ever use aviation fuel in their Harley?
Uh, what they said...100LL is leaded and not for catalytic converters. \\;\\\\\\; Plus we usually mix it with some pump gas (I'm a private pilot, and have the same problem\\\\\\; we have to defuel sometimes for weight and balance and don't want to take a chance storing and re-using the avgas) because the avgas does not have the additives of pump fuel and it absorbs water at a high rate, even though the lead provides for 'anti-knock' properties. \\;\\\\\\; Also avgas has a lower vapor pressure to keep it liquid at altitude and prevent vapor lock. \\;\\\\\\;If you run a lot of it you should keep on eye on the spark plugs. \\;\\\\\\; 100 octane is not much higher than pump high test and many small plane operators get 'stc's' to run 'mogas' in the airplane because it is cheaper. \\;\\\\\\; Have fun, don't worry!
ORIGINAL: Ultrasweet
A friend of mine just told me that he has about 200 gallons of avgas ..... He said he thinks it would run great in my bike. Anybody have any experience with this? T.
My son is the FBO at a local airport. \\; We ran 100 Low lead Av gas in our Harley's Untill the valves started sticking in his Fatboy. 100 LL av gas has 4 times the lead of auto gas. \\; He ran some marvel mystery oil in the crank untill engine got warmed up, drained it, filled with Amsoil and all is well.
ORIGINAL: racklefratz
As mentioned by others, 100LL is leaded, pretty heavily. \\;\\\\\\; Late HDs aren't designed to operate on leaded gas. \\;\\\\\\; That would be enough for me, free or not. \\;\\\\\\; Too much money invested in the bike to experiment with unapproved fuels.
