True Dual or not True Dual? That is the question.
Old 06-25-2008, 08:18 AM
Chrome Sweet Chrome's Avatar
Chrome Sweet Chrome
Chrome Sweet Chrome is offline
Default True Dual or not True Dual? That is the question.
Lots of conversations from stock exhaust to True Duals. What will I gain if I go this route? I have a RKC with stock header pipes and rush slip-ons. Nice rumble not obnoxiously loud. If I spend the $$’s on True Dual headers and pipes will I gain sound, performance, both, or not much at all for the money. Just don’t wanna spend the $$’s on headers, pipes, fuel mgmt, etc…and come away disappointed. Honest opinions?
Old 06-25-2008, 08:24 AM
2008FLHP's Avatar
2008FLHP
2008FLHP is offline
Default RE: True Dual or not True Dual? That is the question.
don't know about the&nbsp\\;true duals but, i put on a V&amp\\;H 2-1 it sounds good but didn't really notice that much of a difference even with remapping my ole '03
Old 06-25-2008, 08:29 AM
extech's Avatar
extech
extech is offline
True duals sound great and do relieve some of the heat put off by factory exhaust, they're not really great for&nbsp\\;performance. I guess, ask yourself why you are considering changing the exhaust, if its for more performance or better sound, looks,ext. then make your choice.
Old 06-25-2008, 08:30 AM
blueflht's Avatar
blueflht
blueflht is offline
the benefits of true duals are reduced heat. also any hp loss can be recuped by slip in reducers at the head. since the left side stock is a dummy the use of aftermarket mufflers with stock headers is minimal. true duals with mufflers and free flowing will in crease hp about 7 to 10 hp. with out free flowing air cleaner no remapping is necessary
Old 06-25-2008, 09:44 AM
huffhuff's Avatar
huffhuff
huffhuff is offline
remove the heat shield on the rear crossover pipe.&nbsp\\;\\\\\\; cut about 4 inches out of the pipe where its round and plug with chevrolet freeze plugs, reinstall the heat shield and you have under $2 true duals.
Old 06-25-2008, 09:51 AM
jsimo7's Avatar
jsimo7
jsimo7 is offline
my wife liked TD's because it removed the rear cyl right side pipe in front of her right foot and I like it for the looks and sound
Old 06-25-2008, 10:20 AM
rochkes's Avatar
rochkes
rochkes is offline
I like the looks and sound of he true duals well enough to give up a little low end tq.
&nbsp\\;
Dennis
Adirondack Bob (03-29-2022)
Old 06-25-2008, 10:22 AM
drrandall1's Avatar
drrandall1
drrandall1 is offline
I went with the Rinehart true duals on my SG. I was totally dissapointed. Waste of money and not that loud. I installed the www.bigcitythunder.com baffles and now love my pipes. But then again I like em loud.
Old 06-25-2008, 10:26 AM
2008FLHP's Avatar
2008FLHP
2008FLHP is offline
ORIGINAL: huffhuff
remove the heat shield on the rear crossover pipe.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; cut about 4 inches out of the pipe where its round and plug with chevrolet freeze plugs, reinstall the heat shield and you have under $2 true duals.
i went the other way before i got the v&amp\\;h propipe...plugged my stocks to make a 2-1
Old 06-25-2008, 10:50 AM
RonH's Avatar
RonH
RonH is offline
Honestly I tried it and was not impressed. The only heat change I noticed was that with TD my left leg got as hot as my right one. The sound was cool, kinda stereo-like, but also a little more high pitched on mine, not as low and rumbling. Plus they caused the bike to run ragged at low rpm so I tried a PCIII to correct that. It worked, but even after a good dyno there were other issues with the PCIII that were troublesome, so I took it all off and went back to stock headers and am very happy with the stock configuration.
Quick Reply: True Dual or not True Dual? That is the question.
