True Dual or not True Dual? That is the question.
RE: True Dual or not True Dual? That is the question.
I absouletly love my TD's! \\; I'm running Rinehart head pipes with CFR mufflers with HP Performance Plus II baffles. \\; The thing rocks, and if I have a loss at low end, I don't notice it one bit. \\; I have a Doherty intake and DTT EFI. \\; My bike will hang with my buddies new 08 street and most times will outrun him!(that will likely change when he changes his AC and tune) The sound is incredible! It sounds like a bagger should ifn' ya axe me! \\;
You don't say whether you RK is injected or carb. You might want to check out the Fullsac conversion for the stock system \\;- eliminates the Y pipe and costs about $180. Very thrifty (fullsac.com). \\;If you have a carb you can rejet and/or modify with a kit from DynoJet. You can do the same with a module \\;for an injected bike. You will see more power, usually 6 to 10 hp. (and torque). Do the air cleaner also if you haven't already. You'll smile the first time you twist the throttle.
The best reason to be rid of the Y pipe is the interference at the Y where one pipe extends into the other at the welds obstructing flow and power. \\;You can clean this up but probably won't feel like reinstalling that thing after all the trouble it \\;is to remove.
ORIGINAL: Chrome Sweet Chrome
Lots of conversations from stock exhaust to True Duals. What will I gain if I go this route? I have a RKC with stock header pipes and rush slip-ons. Nice rumble not obnoxiously loud. If I spend the $$’s on True Dual headers and pipes will I gain sound, performance, both, or not much at all for the money. Just don’t wanna spend the $$’s on headers, pipes, fuel mgmt, etc…and come away disappointed. Honest opinions?
https://www.hdforums.com/m_2534631/tm.htm
Here's the Fuel Moto link. Notice the excellent torque curve on his dyno chart.
http://fuelmotousa.com/rush_fuelmoto
I've got an '01 RKC that I switched to V&\\;H Dresser Duals. Before I had stock pipes and V&\\;H Basic slip-ons. A great mod in my opinion. The sound is louder but not dramatically but is deeper and in stereo. It also has a great sounding glug-glug-glug while at idle. Sort of like a boat exhaust that is underwater. Opened up, she barks. As for performance, I couldn't tell by the seat of my pants. Note, I do have a Power Commander that I remapped when I did the switch.
