Best mount for ZUMO 550 w/ Bat wing?
RE: Best mount for ZUMO 550 w/ Bat wing?
ORIGINAL: bigdumbnoitall00
the mount that comes with the zummo should work there is an existing plate that u have to screw to the mount it has a variety of holes in it they will probably aline with you existing hole s
Ok thanks I will see when I get it, HOWEVER, next post
Kuryakyn has a mount called " Fuel Door GPS/Accessory Mount looks pretty good.
http://www.kuryakyn.com/products.asp...&\\;ci=3886
Ed
Ed
Nice install RonH - I was thinking of the same location. Much better than the handle bars. You don't have to look to the side to see it. Did you just use a Ram Ball with a threaded mount? I asked if anybody had tried mounting it in the center over at www.zumoforums.com but no one has responded. I would appreciate any tips & additional photos showing the mount itself if you have any.
ORIGINAL: bagman1
+1
ORIGINAL: Uncle Fester
I got the Kuryakyn fuel-tank mount. Works like a champ for me. Cleaner than the handlebar mounts, plus easy to reach with either hand. \\\\\\\\\\\\\\;
What about the wire from GPS to power and the radio so the sound comes through the bike speakers?
Thanks for all the responses
