Soft lowers for the rain and cold?
Old 06-23-2008, 08:06 PM
timbakersr's Avatar
timbakersr
timbakersr is offline
Default Soft lowers for the rain and cold?
Well I order those soft lowers for my EG and now I find two things. One they can only be used when it is above 50 degree's?? and the one's from Harley that have the shield on them wont line up with the hwy pegs, ( hole in the lowers that is ) so now I have to get something else. I wonder why the things wont accomidate the hwy pegs?
Old 06-23-2008, 08:10 PM
Domestic Violence's Avatar
Domestic Violence
Domestic Violence is offline
Default RE: Soft lowers for the rain and cold?
i have the faux-leather lowers from HD. the 'holes' line up for my hwy pegs and attach with buttons.
&nbsp\\;
true- when temps are over 50, they should not be used.
&nbsp\\;
they do a pretty good job keeping the cold/water off of your feet though.
Old 06-23-2008, 09:19 PM
Fletch's Avatar
Fletch
Fletch is offline
Mine matched up with the pegs perfectly. Perhaps just dumb luck that my pegs were already in the right location. Maybe move your pegs a bit?
Old 06-24-2008, 07:37 AM
frog13's Avatar
frog13
frog13 is offline
ORIGINAL: timbakersr
It's BELOW 50 degrees, although I have run mine up to about 70, she starts building heat after that.&nbsp\\; You might have to tweak the highway pegs a bit to match the hole.
Old 06-24-2008, 07:56 AM
FLHT's Avatar
FLHT
FLHT is offline
Check these out
http://www.airlite.ca/index.php?id=1
They are pretty sweet. True you arent supposed to use them above 50, but if it were raining I think you may be ok.
Old 06-24-2008, 08:57 AM
BEAST's Avatar
BEAST
BEAST is offline
I put the wifes on in the spring, in the mountains, and in the late fall. I had to cut holes in them for her fog lamps, but the highway peg holes are ok. I still don't know why they would block much more, if any, air than lowers on a Ultra though.
Old 06-24-2008, 10:27 AM
Neckball's Avatar
Neckball
Neckball is offline
If you think about it, anywhere HD put the slot for the pegs is going to cause someone problems, too many different ways to mount 'em.&nbsp\\; My wife and her sewing machine fixed mine for me.&nbsp\\; It's a simple job.
Old 06-24-2008, 07:43 PM
bigskyhd's Avatar
bigskyhd
bigskyhd is offline
THey're on my list to get, just to have in the tourpak in case...&nbsp\\;
Old 06-24-2008, 08:09 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
they were ok on mt rk&nbsp\\; right boot stayed dry but dam if the left one didnt get soaked like the cover wasent even there and i used up to about 70 with no problem as long as no traffic.
Old 06-24-2008, 08:25 PM
iann8ik's Avatar
iann8ik
iann8ik is offline
soft lowers are great. my pegs didn't line up either so the daughter turned them inside out and ripped the seam and resewed them on her sewing machine. ain't daughters wonderful!
Quick Reply: Soft lowers for the rain and cold?
