Streamliner shift pad
Hello-
Sometimes what should take 5 minutes takes an hour. I got a Streamliner shift pad for my from shifter. I thought it would just screw out.I cut the rubber off the end to see if there was a hex end or something, but no. Finally with locking pliers it moved slightly. I even tried cutting a slot with the Dremel tool to try and get some leverage. No go. Back to locking pliers and after much sweating it loosened up. It was red Lock-tited in. Directions in the new one said apply heat but I didn't want to torch near the chrome primary. Almost an hour later, it's on and looks great, but I'm not sure I want to go through all of this to do the back shifter!
Cheers!
By the way, only one space after a sentence and no return between paragraphs will keep out the /////////////'s!
Cheers!
ilikethewoods
04-26-2011 06:16 AM
