Whining Rear
Old 06-25-2008, 08:47 PM
Harley Stan's Avatar
Harley Stan
Harley Stan is offline
Default RE: Whining Rear
Have you changed your tires?&nbsp\\; I switched to the Metzlers and the rear is a little wider than the original Dunlop, I&nbsp\\; noticed that the flap between the belt and the tire rubs the tire just a hair, it is not damaging the tire but it makes an odd noise while going down the highway. I notice it most when traveling on concrete&nbsp\\; or next to walls that echo alot.&nbsp\\; I just found it after reading this thread and answered my own concern.&nbsp\\;
Old 06-25-2008, 09:16 PM
Hydraboss's Avatar
Hydraboss
Hydraboss is offline
Mine goes in tomorrow for the same thing.&nbsp\\; At 22kph rolling it starts to howl like a banshee, but the sound is on the brake side not the belt (2007 FLHX).&nbsp\\; I'm also having them "look" at the dragging brakes front and rear.&nbsp\\; This is not a belt problem (I'll post when they give me the "never heard it before...not warranty" story.
Old 06-29-2008, 11:01 PM
RKTonyC's Avatar
RKTonyC
RKTonyC is offline
Well, thanks everyone for their input on this issue. Before I did anything, I decided to check the easiest before digging into anything. So I pulled the bag off the left side, and checked the belt. And, you got it, it was tight as hell. I adjusted the it properly, and the damn noise is gone.
I was going to remove the rear wheel and change the rear bearings. And if&nbsp\\;I did it blindly, I would have missed it it being just the belt, and thought it was the bearings. I hate it when simple things are over thought.
But, I did check into the cam tension problem more&nbsp\\;after Fla Glide's suggestion. Its defintely a big problem for a lot of people, so Im glad you brought it up man.
Jess beachie
07-30-2023 06:48 PM
muyak1
08-17-2012 10:27 PM
willcatchum
Wheels/Tires
07-26-2012 08:31 PM
JackGib46
07-24-2012 11:18 AM
cavscout822
07-07-2011 11:59 PM
Quick Reply: Whining Rear
