Kuryakin ISO throttle grip too stiff
Old 06-22-2008, 04:21 PM
Ultrasweet's Avatar
Ultrasweet
Ultrasweet is offline
Default Kuryakin ISO throttle grip too stiff
Just had Kuryakin ISO grips installed yesterday on my 08' RG. Normally would put them on myself but they offered to put them on for free. Noticed today that the throttle does not return by itself. Anybody got any suggestions? T.
Old 06-22-2008, 04:29 PM
dawg's Avatar
dawg
dawg is offline
Received 3,222 Likes on 1,839 Posts
Default RE: Kuryakin ISO throttle grip too stiff
Make sure the rib is not binding in the switch housing.
Old 06-22-2008, 08:19 PM
UltraDave's Avatar
UltraDave
UltraDave is offline
Another possibility is the throttle cables are&nbsp\\;not adjusted correctly after they put on your new grips.&nbsp\\;
&nbsp\\;
In case your interested, I put on the ISO grips last year.&nbsp\\; I really like the look and how they feel.
&nbsp\\;
&nbsp\\;
Old 06-22-2008, 08:26 PM
Badbagger's Avatar
Badbagger
Badbagger is offline
Put em on mine and love em... and btw, what Dawg said.
Old 06-23-2008, 05:02 AM
LKHA's Avatar
LKHA
LKHA is offline
When I did mine had the same problem. Loosen up the control and move the grip out just&nbsp\\; a tiny bit worked for mine it was bottoming out on the bars hopes this helps.
Old 06-23-2008, 05:51 AM
kyote's Avatar
kyote
kyote is offline
just a thought...Check to be sure yer "star" thumbscrew is out enough.....they coulda' used it to hold the grip from moving...
Old 06-23-2008, 07:40 AM
katobird's Avatar
katobird
katobird is offline
yup,
throttle friction stop not installed correctly or already "set"
&nbsp\\;
i had to sand off so rough edges where the cables aligned and had to be careful about the cable housing.took an extra hr to get all the binding out
&nbsp\\;
good grips though
Old 06-23-2008, 08:05 AM
barkster99's Avatar
barkster99
barkster99 is offline
All the above, plus...
&nbsp\\;
Someone mentioned in an earlier thread to lube the handlebar under the throttle sleave. I've never had to do that but - it makes sense.
Old 06-23-2008, 11:39 AM
PREACHER's Avatar
PREACHER
PREACHER is offline
Thanks for the info the ISO grips are my next addon.
Old 06-23-2008, 12:06 PM
Ultrasweet's Avatar
Ultrasweet
This morning I loosend the housing and slid the whole thing about 1/16 inch out. Fixed the problem. I think when the guy installed it he pushed everything all the way too far in and then tightened up the housing. The grip must have been putting to much pressure against that sensor that is in the end of the handlebar. T.
Quick Reply: Kuryakin ISO throttle grip too stiff
