No way to change handlebars on '08 TBW???
Have a friend who is looking at buying an 08 Ultra, but has been told by several salesmen that you cannot raise the handlebars on these bikes due to the tbw. He has a bad neck, and needs apes to reduce the strain on longer rides. Is this true? Doesn't seem like Harley would do this since so many change out the bars....
RE: No way to change handlebars on '08 TBW???
That is not true the dealershio that I work at has put many apes on 08 touring bikes. Drag specialties has a few bars that have the notches for the fly by wire system. that only thing is that you will have to get an extension for the wiring that is run internally is the bars. Of course you are going to need a new brake line and clutch cable but that is a no brainer.
Well it didn't ring true with us either, but the dealerships in both Temple, Texas, and our local one in Lexington both told us it was a no go due to the tbw. I guess we should probably have been asking the service dept rather than the salesmen, but since he was trying to buy one, that's who we were talking to..
1. Wild 1 WO-575 Bars http://www.wild1inc.com/handlebars.html
2. Krome Werks Sweeper Bars http://www.khromewerks.com/
and if you want to higher (apes) extensions for the TBW http://www.namzcustomcycleproducts.c...Wire%20Ext.htm
