I was using wrong torx
Did an oil change along with primary &\\;\\\\\\; tranny today. Switched everything over to HD syn 3. Two of the 5 tork bolts stripped out. Had to use easy out to get loose. One wouldn't come so used a chisel to get it loose. SUCKS!! Got some new bolts from HD shop and when I went to tork to the proper lb's, 2 of them stripped again, tightening them. I'm using a craftsman T-25. I'm slightly tapping it in before tightening to proper tork, and it still strips. \\;\\\\\\;Harley shop said this is a very common issue. They told me to drive the next size up tork head into the bolt with a hammer to get it loose?? \\;\\\\\\;That idea \\;\\\\\\;sounds like trouble to me. Pisses me off cause \\;\\\\\\;I bought \\;\\\\\\;5 chrome bolts and 2 are now stripped already just waiting for the next oil change "challenge". None of the five bolts are torked properly. There all good and tight, but not 84 and over. There has got to be a better way? What about socket heads. I was always told they strip even easier than tork?
RE: Derby cover bolts SUCK!!
ORIGINAL: ultranut
Part of your problem might be that those take a T27.
damn dude, that sucks. \\; but you can't really bitch about them since you did it by using the wrong size tool. \\; i have never had any problems on my road king (cause i learned the hard way on my sportster! lol) but, use a quality tool (not harbor freight!), tap it slightly to seat it fully, don't overtorque when tightening, and use some anti-seize when reassembling. \\; that should help alleviate any issues that you might have.
ORIGINAL: stro1965
ORIGINAL: ultranut
Did an oil change along with primary &\\;\\\\\\;\\\\\\\\\\\\\\; tranny today. Switched everything over to HD syn 3. Two of the 5 tork bolts stripped out. Had to use easy out to get loose. One wouldn't come so used a chisel to get it loose. SUCKS!! Got some new bolts from HD shop and when I went to tork to the proper lb's, 2 of them stripped again, tightening them. I'm using a craftsman T-25. I'm slightly tapping it in before tightening to proper tork, and it still strips. \\;\\\\\\;\\\\\\\\\\\\\\;Harley shop said this is a very common issue. They told me to drive the next size up tork head into the bolt with a hammer to get it loose?? \\;\\\\\\;\\\\\\\\\\\\\\;That idea \\;\\\\\\;\\\\\\\\\\\\\\;sounds like trouble to me. Pisses me off cause \\;\\\\\\;\\\\\\\\\\\\\\;I bought \\;\\\\\\;\\\\\\\\\\\\\\;5 chrome bolts and 2 are now stripped already just waiting for the next oil change "challenge". None of the five bolts are torked properly. There all good and tight, but not 84 and over. There has got to be a better way? What about socket heads. I was always told they strip even easier than tork?
Well it would appear that our local HD shop is using the wrong size tool as well  \\; They are the ones that told me to be sure to use a good T-25. I am using a craftsman set, not Harbor frieght. Guess I'd better get the right tool next time. I still think the bolts are pretty damm soft. They drilled out very, very easy for the easy out. I just got back from a little ride and nothing is leaking so we are good. BTW, I thought that tork tool didn't fit tight enough
Here is an easy fix to this old and ongoing problem. Replace the torx head screws with stainless steel allen head screws. I've done this with \\;all the \\;Big Twin Harleys in my family (a dozen and counting) It sure makes screw removal a lot easer next time around.
You should be able to find the stainless screws in the correct size at any good hardware store.
Use a little BLUE locktite on the screws and DON'T torque them too tight. You will never have this problem again.
 \\;G wizz
 \\;G wizz
