Oil Temp Guage
Oil Temp Guage
I had an oil temp guage installed on my 07 SG last winter at my HD dealer. \\; Because it was the cold part of the year I thought it was working. \\; I've had it in to be checked out 3 times, the last one today, when they replaced the whole thing. \\; It's installed into the bottom plug on the oil pan using the NAPA fitting. \\; I still don't think it is working. \\; On the way home, it got up to about 160 degrees. \\; It's 90 degrees out and I ran it about 10 miles at 80 mph. \\; Should'nt the oil be hotter that that? \\; I don't have an oil cooler. \\; Can anyone tell what their oil temp guage is registering? \\; Thanks.
RE: Oil Temp Guage
Yeah, the oil *is* hotter than that. \\; I have a gauge installed the same way yours is &\\; I also have the digital dipstick gauge. \\; My fairing gauge usually reads about 180/190, &\\; the digital gauge reads around 220/226. \\; Harley has motor cooling down pretty good. \\; I installed an oil cooler to see if it would help with the motor heat, but even if I cover the cooler I can only force the fairing gauge to read between 205 &\\; 220 while the digital gets up in the high 230's.
RE: Oil Temp Guage
Thanks for the info. \\; I'm leaving tomorrow morning for the Elko Biker Rally in Elko, Nevada. \\; That's 300 miles of 4 lane desert riding and it's supposed to be about 90 degrees. \\; That should tell the tale if it's working or not. \\; Ride safe and thanks again.
RE: Oil Temp Guage
With air temp btw 90-100F as is normal for this time of year in Sacramento my gauge \\;always reads 220-230. \\; Was idling in line waiting to enter yosemite this past weekend with air temp near 90 gauge was reading 280. \\; I have oil cooler and have never seen the gauge less than 200 after warm up with air temps 80 or above.
