Cam Upgrades - I gotta question
Old 06-19-2008 | 11:24 AM
tgaetto's Avatar
tgaetto
Default RE: Cam Upgrades - I gotta question
I was chasing a lifter noise since day one and it turned out to be the compesator sprocket nocking. Since I did the 24t sprocket and shimmed the bolt all quiet I mean just the way an air cooled motor should sound!!
Old 06-19-2008 | 02:36 PM
PhilM's Avatar
PhilM
Alignment is simple...
Place a new rocker box gasket on the head & then lay the rocker box in place. Thead the tapered alignment pins (referenced above), into the two center holes (the ones the vent assy bolts to) and snug them in place. The taper on the shaft will "center" or "square" up the boxes on the head. Follow the directionsbin the svc manual to bolt the box in place, then remove the alignment screws and continue assembly.
Regarding shimming the rockers.... You'll need to measure the lateral play between the rocker and the rocker support plate. If the play is greater than .004", then you can get some shims to fill the gap. I got mine from McMaster-Carr online. I have read that .006 is the thinest shims you wanna use for durability reasons. I have measured gaps anywhere from .010" to .020", so .008", .010", & .012" seem to be the most common shim thicknesses - at least for me.
Old 06-19-2008 | 07:47 PM
2005UltraNC's Avatar
2005UltraNC
Thanks Phil
californiafatbob2013
Engine Mechanical Topics
08-24-2014 04:36 PM
Madcop
08-14-2014 09:52 PM
red deuce
08-03-2008 05:08 PM
jcboof
07-17-2008 09:01 PM
mk2007
Ironhead
07-06-2008 07:55 AM
Quick Reply: Cam Upgrades - I gotta question
