RKC AIr Suspension ???
RE: RKC AIr Suspension ???
I'm about 75 lbs heavier than you and I always ran about 15-18 lbs in my RKC air shocks. \\; I got tired of feeling every little bump in the road, so I replaced them with some Progressive 416's. \\;The difference was amazing. \\;Consider some 416s...your L5 \\;will thank you.
I just got a new RKC also. \\; You might want to check the manual. \\; It gives you weight ranges for rider and passenger. \\; You are probably also going to want to buy the Harley pump for the air shock. \\; It really takes the aggravation out of trying to properly inflate the shocks.[sm=icon_cheers.gif]
+1 on the harley pump, that was a 40.00 investment that removes frustration getting air into the shocks. \\; Do NOT use a high pressure compressor. \\; I am about 250 and run 15 LBS. \\; The shocks seem to loose air over some time, so I check them with each long ride.
ORIGINAL: tommyellison
Being new to the feel of a Harley, I need to ask a question....
What is the proper PSI for the rear suspension? I weigh 275. I cannot tell if the ride I 'm getting is right or if my old L5 disk is just getting a little sensitive.
Help!
Tommy
Help!
Tommy
Tommy, get the HD pump.
It's well worth the money.
