Pull back bars on ULTRA with ABS
I asked my local wrench about installing new bars to change my hand position and pull back the reach and he told me that I cant due to the ABS brakes.
This was the same response I got from my salesperson when I asked for steel braided brake lines up front to go with my chromed front end......can't due to ABS......
So the questions is: Does anyone one have a solution or know when you might be able to retrofit a longer line on the bars to facilitate the pull back bars and the braided lines up front??
Thanks, Lance
2008 Ultra
Thanks, Lance
2008 Ultra
Guest
Posts: n/a
You can change your bars...If you are not comfortable doing your own work find a local independent...Depending on the bars you may need to buy extended lenth trottle and control cables, an extended clutch cable, and a new extended brake line (ABS rated)...I have Wild1 575s on my ABS Ultra.
I put 2" pull back bars on my 08 street glide with ABS. If you need a longer brake cable then you can get a hydraulic brake line from a manufacturer\\\\\\; that is what my independent mechanic did.
the handlebars will have to be cut with the notches for the throttle.
+1 on the Khrome Werks Sweeper bars Part # 300515. No mods other than extended clutch cable. They are 1" pullback and 2" taller and have a great hand position and are already notched for the 08 TBW. No extensions to the TBW are necessary. Tell your HD dealer that. You can order them from a sponsor of this Forum (Warehouse Direct) and get the bars and a +4 Barnett (black) clutch cable for $100.22, they give us HD Forum members a 15% discount.
Thanks DAWG for the recommendation !!!!
Need help with part number and where to buy a longer DOT approved ABS brakeline.
My shop insist that there is not enough room on the factory line to put the +2 sweepers, 6" wider and 2" taller, they say \\;absolutly not enough stock cable for this. They are willing to try but I have to pay the labor to try and put it back if it does not fit.
Thanks,
Thanks,
ORIGINAL: navigator
My shop insist that there is not enough room on the factory line to put the +2 sweepers, 6" wider and 2" taller, they say \\;\\\\\\;\\\\\\\\\\\\\\;absolutly not enough stock cable for this. They are willing to try but I have to pay the labor to try and put it back if it does not fit.
Thanks,
Thanks,
http://www.scootworks.com/
