Idle reset for 08 touring models with electronic throttle
I learned today of a idle reset tip for my 2008 Road King Classic. My idle was too high and I found out that the electronic throttle sets the idle point at whatever rpm the bike was at when shut down last if shut down improperly. I had switched off the main ignition on the tank before I had turned off the run switch on the handlebar and had not let the bike wind down to idle speed before doing so. I guess I was in a hurry or maybe it was just a brain cramp. A tech at the dealer told me that it could be reset if I did the following:
Make sure the main ignition on the tank to off then turn the handle bar run switch on. Then turn the main switch on the tank on for 2 seconds and then off for 2 seconds. Do this last step four times ending in the off position.
It worked- the next time I started the bike the idle was correct.
I think the two thing that I did improperly as I was getting used to a new bike was to shut off the main ignition switch (on the tank) instead of killing the engine with the handlebar mounted 'run' switch first. The seconed thing was to not let it reach idle speed before shutting it down. I'm not sure which one of these caused the problem or if it was both in combination
ORIGINAL: cragdweller
08, 2009, davidson, electric, electronic, electronics, handlebars, harley, idle, king, low, reset, road, roadking, throttle
