Roadglide CB
RE: Roadglide CB
BBC,
Trying to do the same thing to a friends police bike. It seems the CB antenna for the tour pak has a disconnect located inside. The frame mounted antenna does not so you can't switch between the two. I've been trying to find a solution for the frame mount but haven't had any luck. I'm not sure if a disconnect can be inserted in the line without affectting the SWR. If you come up with a solution please let me know.
BBB
BBB
RE: Roadglide CB
QD antenna hardware is available.....you just may have to go with a different antenna.....check http://www.aesham.com/ or http://www.randl.com/shop/index.shtml to start with...if you know any amateur radio ops..( Ham's ).. they will help ya..
