steering dampner
RE: steering dampner
ORIGINAL: mikeisglidn
its an ugly little shock absorber that attaches to a fixed position (frame) to the steering rod or fork in a bikes case to help prevent the steering from shaking back n forth our glides are pretty limited on turning radius now.....not sure if a dampner would limit the radius even more....and did i mention theyre UGLY!!
My question is this are you having a weave problem. or a wobble. You see I had an earleyer post about about tankslappers on FL platform bikes. In The factory has been making changes to the bikes to remedy this and have improved somewhat. One thin you should consider is your cleave blocks. Thes are your pivots for the swing arm and tranny mount. They were made more ridged in 2002. so was the swingarm but you would have to change axels for that one...So change your cleave block bushings and another tip is make sure your front motermount is in tact. Some times they tear and on the right circumstances will induce a weave.
Later
John A. Gonzales[8D]
Later
You know I had another thought. The fl platform bike also has onley a 26 degree rake. so if you lwered the back of the bike with a set of 11.5 shocks you would get just a fraction more and if you use a good performance shock like a heavy duty progressive suspention 412 the bike will feel more firm. and they blow Harleys short airshocks away.
Later
Later
Received 1,297 Likes
HD used to offer a front end with adjustable trail for sidecar equipped bikes. You set it up normal for solo use, and adjusted it for more trail with the sidecar on. Don't think it's available any longer, so now the thing to do is install a steering damper. Some dampers can be adjusted to whatever level is needed for a particular bike.
Things can get a little squirrelly with the sidecar in place, and headshake can sorta spoil the day. Ya might not fall over from headshake on a sidecar bike, but it'll make it so you can't ride tha bike. Headshake doesn't have to even be a problem at higher speeds. I had one so violent on my '87 FLST that it literally shook the bolts loose that hold the risers to the top triple tree. This shake occurred at about 35mph.
