there is a tab on the header that mates up with the tranny bracket. \\; does the header tab go on top of or below the bracket on the tranny. \\; thanks for the help.
On mine the trans bracket was on on top of the header bracket. If you assemble everything loosely first, it will go into it.\\'s natural position, just to make sure yours is the same. Good luck and enjoy your cat...they're great.
I ended up putting mine on top of the tranny bracket. Once you get everything on and loosely connected, check to see which way the tab (over or under) fits better. Don't think it matters as long as everything is lined up properly before final tightening.
