Vibration
RE: Vibration
ORIGINAL: matrix5
Had the same issue on mine. If you notice, the crossover pipe you removed served as an exhaust flow and also a support brace for the rear of the engine. \\;\\\\\\;\\\\\\\\\\\\\\; It tied into your right side pipe and that mounting bracket hooked to the frame right below that. Crossover gone = less support = more vibration at idle. \\;\\\\\\; No fix that I'm aware of. \\;\\\\\\; I do notice people looking at it shake at stoplights though.
ORIGINAL: pingman68
the rpms are the same as before she just shakes ALOT more than it did!!
That makes sense \\; Thanks!
RE: Vibration
ORIGINAL: matrix5
ORIGINAL: pingman68
On every HD Touring model, the exhaust pipes only attach to the frame, at the very tail end of the muffler, and this is a rubber mount also.
The 2 mounting brackets you are thinking of are attached to engine/transmission assembly, not the frame.
Mounting the exhaust of a rubber mounted motor to the frame would be................bad.
