PCIII and CVO injectors
Has anybody had the CVO injectors installed on their '06 who is also running a PCIII? My Glide is in the shop getting the CVO injectors installed, but once I finish the break-in period, I'm installing SEII slip-ons and the air cleaner. I just wonder if the existing download is good enough, or if enough has changed w/ the CVO injector and re-map to make a difference on this common and mild setup? I'm guessing Dynojet will eventually come out with "late"-06 maps in addition to the existing "early"-06 maps, but I was wondering if anybody has this setup now (CVO injectors/SE slip-ons/SE A/C) with thier PCIII and having either success or trouble.
Thanks,
Scott
2006 FLHTCI Vivid Black
Thanks,
Scott
