What if I throw in HQ0039 cams?
No, I'm not pulling the heads and reworking anything. 02 FLHTCUI with the 04 SE 103 stroker kit. Yes, the cams are 253s. The compression is only 9:1 mabey a little more since it has 35k on it. I am only in the can-chest doing maintenance. Barrings, Tensioner, Lifters and cams. Seeing I have to spend money on cams, putting something different for more low end torque can't heart. It has always been a little lazy between 2k and 2.8k. Has anyone used this combination?
SE AC
Stock header
SE II Slip-ons
SE AC
Stock header
SE II Slip-ons
RE: What if I throw in HQ0039 cams?
Thanks Gil for the info. I PMed phil and I hope he can lead me into the right direction. The normal response to other peoples cam questions end up with "You need to change, work the heads, Higher compression etc..." I have what I have and I am basically stuck with it until we start smoking or knocking! \\; Thanks again!
