What the hell is wrong with my front brake?
I had the front tire replaced last week on my '06 RK Classic (21K miles). \\; When I picked it up, there was no front brake\\; the lever pulled all the way to the throttle grip. \\; I took it back the shop (not a HD dealer) and told them they must have left air in the line. \\; They bled the line (many times) and could not get proper brake \\;lever action back. \\; They dismantled the calipers, removed the pistons and reinstalled, and got the same results. \\; There is not sign of oil leaking and he said the pistons, etc. looked very clean, no scoring or scratching. \\; He decided to install a complete seal kit and thought he fixed it. \\; I picked up the bike and rode it but it's still the same. \\;
If the bike is not moving, you can pump the brake lever and it will grab after the 2nd or 3rd pump. \\; Once the bike starts rolling, the lever action will go all the way to the grip. \\; The brake was working fine before I took it in. \\; They can't figure it out and I can't understand how just by removing the wheel, \\;why the front brake would stop working...???
I don't think the rotors are warped but I havn't physically checked either. \\; Any ideas out there????
1 Post
RE: What the hell is wrong with my front brake?
ORIGINAL: Rick51
A warped rotor would not cause loss of brakes. Sometimes non-HD mechanics are not that cheap or good.
As suggested, do a search here on brake bleeding. You will find a link to another forum with reverse bleeding setup that worked great on my 07 rk when I replaced my lines withbraided lines. Here's the link...good luck. \\; http://www.moccsplace.com/images/bra...er/bleeder.htm
kbuckz06
12-11-2010 08:58 PM
