Found Problem, Now What? - Vibration Around 2500 RPM
Old 06-04-2008, 09:14 PM
rahall's Avatar
rahall
rahall is offline
Default RE: Vibration Around 2500 RPM
Are you guys talking about changing the front rubber mount just below the voltage regulator.
&nbsp\\;
If so, did you just use an exact Harley replacement?
&nbsp\\;
It looks okay, but I'm willing to give it a try.
&nbsp\\;
Old 06-04-2008, 09:36 PM
jrdfatboy's Avatar
jrdfatboy
jrdfatboy is offline
I have the same thing on my 07 street glide. My vib is at 2700- 2900 rpm,with stock pipes and now with&nbsp\\;newly installed rush pipes. It has been that way since it was new, I now have about 6500 mi on.
Old 06-06-2008, 12:21 AM
*Shadow*'s Avatar
*Shadow*
*Shadow* is offline
Yeap.....Harley part, and it was under warranty
Old 06-06-2008, 07:03 AM
daytonasteve's Avatar
daytonasteve
daytonasteve is offline
6th Gear
Be prepared for a whole new set of vibs with the new mount.&nbsp\\; It's harder rubber, and frankly crap.&nbsp\\; I went searching through the trash for the old one, unfortunately couldn't find it.&nbsp\\; Everyone says it will get better, I hope so.&nbsp\\;
Old 06-06-2008, 05:37 PM
pittguy's Avatar
pittguy
pittguy is offline
Changing the mount is cheaper than building a true crank .
Old 06-09-2008, 06:45 AM
rahall's Avatar
rahall
rahall is offline
Thanks Sean.
Your right, all I had to do is fold up the highway pegs and the vibration is gone.
Now what?
Is there a solution?
&nbsp\\;
Any ideas, anyone?
&nbsp\\;
Old 06-09-2008, 08:18 AM
Neckball's Avatar
Neckball
Neckball is offline
https://www.hdforums.com/m_2531793/tm.htm
Old 06-09-2008, 11:16 AM
rrsjs5's Avatar
rrsjs5
rrsjs5 is offline
ORIGINAL: rahall
Thanks Sean.
Now what?
&nbsp\\;\\\\\\;
Any ideas, anyone?
&nbsp\\;\\\\\\;
&nbsp\\;
Check the center bolt on the engine guard,my old road king did the same thing,bolt was loose!
Old 06-09-2008, 07:28 PM
blueflht's Avatar
blueflht
blueflht is offline
try ebay for the motor mounts. i found a place with some early 90 mounts for 12$. same fit but better rubber.
Old 06-09-2008, 08:07 PM
quackhead's Avatar
quackhead
quackhead is offline
so who has tried the Buell mount and what is your opinion on it. my 07 SG shakes like crazy at idle. maybe this would help some.
Quick Reply: Found Problem, Now What? - Vibration Around 2500 RPM
