MY LEG IS BURNING....
I have a question in reference to Reinhart pipes on an 07 Electra Glide. Every time I ride, it seems that I burn my left thigh on the pipe. I have read similar reviews from other people on this forum and wonder if there is a true fix to this issue. I have seen people install 2 into 1's and I have heard people talking about heat deflectors. I'm afraid if I go with 2 into 1 pipes that I just move a lot more heat to the right side of the bike making it almost unbearable, would this be a true statement??? I've heard some good reviews on the rjoriginal heat deflectors. This has to be a very common problem and would like to know what works. Thanks in advance for any guidance. -Chris
RE: MY LEG IS BURNING....
I had the EXACT thing happen to me on my Ultra. Before I took delivery of the bike, I asked about true duals. The dealer said the only true duals they recommend and install were Rinehart True Duals, so I went with it. Severely burned the inside of my left thigh and went back to the dealer the same day (had less than 200 miles on the bike). We examined my bike and a bone stock Ultra and found out the pipe on the left sticks out almost 2 inches farther! I had them re-check the air-to-fuel on the dyno again, which wasn't the problem. I had a Fat Boy with D&D Fat Cats on it that was great and had a Road King Classic with Thunderheaders (both 2 into 1 systems exiting on the right side) and had zero burn problems. After consideration, I decided to have the D&D Fat Cats installed with the ghost pipe. I don't expect to be burned again by a pipe that sticks out too far. Just my 2 cents!
