MY LEG IS BURNING....
Old 06-04-2008 | 06:58 AM
cmcsns's Avatar
cmcsns
From: Beverly Hills, Fl. Swimmin pools. Movie stars
Default RE: MY LEG IS BURNING....
I run Rinehart TD's and haven't burnt myself yet. Maybe I've just been.... uh......lucky? I went to my Dr. the other day and told him "it hurts when I do this", he said "don't do that"......
Old 06-04-2008 | 07:00 AM
Windup08's Avatar
Windup08
RJs originals....I've never burned myself, but can feel the heat....RJs will keep it off your legs.
Old 06-04-2008 | 07:27 AM
Neckball's Avatar
Neckball
We examined my bike and a bone stock Ultra and found out the pipe on the left sticks out almost 2 inches farther!
The reason for this is the head pipe is so large it can't be tucked in as tight as a smaller diameter pipe. You can use Vance & Hines Dresser Duals or Rinehart Cross Dresser head pipes which are both 1.75" diameter ( same as stock ) and then use Rinehart slip-ons and get the same look and sound. Nobody will be able to tell the difference from 10 feet away. On a stock engine the smaller diameter head pipes may even work better in the low and mid-range rpms.
Old 06-04-2008 | 08:26 AM
mariner227's Avatar
mariner227
I had the same problem. Replaced the stock exhaust with V&H 2 into 1 and ended the problem!
Old 06-04-2008 | 08:33 AM
bulldogmoe7's Avatar
bulldogmoe7
GO WITH FULLSAC DUELS. WORKS GREAT AND NO ISSUES HERE
Old 06-04-2008 | 09:52 AM
SoCal_Pappy's Avatar
SoCal_Pappy
added set of RJ's original on my '07 worked well for me & passanger...
Old 06-04-2008 | 09:54 AM
HelluvaDoormat's Avatar
HelluvaDoormat
cmcsns
Date 6/4/2008 4:58:16 AM
Glad you haven’t gotten burned. How much did you pay for that visit? Next time just post your issues on this forum and get some FREE advice![sm=pcwhack.gif]-Chris
Old 06-04-2008 | 03:47 PM
HelluvaDoormat
I'm going to order the RJ originals per the posts I've seen here. If these don't work, I guess I'll need to look at replacing my pipes.
Old 06-04-2008 | 04:10 PM
texan321's Avatar
texan321
ORIGINAL: HelluvaDoormat
where do you order these?
Old 06-04-2008 | 04:35 PM
sportyrider1's Avatar
sportyrider1
Had the same problem with a set of samson dresser duals (true duals) didn't have a single pair of jeans with out a burn hole in the left inner thigh. replaced it with a supertrapp supermeg 2-1. no burn on the left and because the rear pipe goes foward before it loops back no heat problem on the right either
Quick Reply: MY LEG IS BURNING....
