fuel pack or power commander
i have an 06 street glide with hooker slip ons, stage 1, and power commander, i'm swapping to a 2-1 lsr exhaust, screaming eagle heavy breather, now, the question, should i stick with the power commander or use the vance and hines fuel pack? i already have the fuel pack from another application. i've heard of the power commander just shutting down and if the fuel pack ever quits i can just plug the stock 1 back in and keep riding. i'm getting re-tuned after it is all installed.which is the best way to go? thanks
RE: fuel pack or power commander
I just installed V&H Bigshots(black) and Fuelpak. I love it. Only been riding it for a week but I tell you what, I installed according to directions and programmed from V&H site, not one problem! Sounds freaking great, no backfire or anything! Best set-up I've had out of three bikes! Had the USB Power Commander III on my 02' Softail, didn't care for it much but I do like the Fuel Pak. Don't know if this helps but for what it's worth.....
I have the LSR on my 08 with a PCIII. I wouldnt even consider a fuelpak as there is no "tuneability" compared to the PC. Your gonna run an LSR get it dynoed and tuned correctly and you wont be disapointed.
I have the capability to try numerous pipe applications and the LSR was the top numbers maker......D&D was a close second......
Fuelpak is a great way to go.&\\;nbsp\\; Easy to install and completely idiot proof.&\\;nbsp\\; Their customer service is great and always helpful.&\\;nbsp\\; If there are any problems you use pull it off and re-connect the factory plugs.&\\;nbsp\\; I like the fact it doesn’t change the computer and you can take it off.
ORIGINAL: \\;\\\\\\; smitty901
Seems PCIII are nothing but problems for many users
BTW, I'm not inserting all these weird characters in this message. \\; I've typed it over five times and can't keep them out, only to re-appear when written to the forum.
