disable rear cyl???
disable rear cyl???
when I was getting my twist grip sensor replaced at 50 miles,the tech said something about rolling the throttle forward for so long and it will disable the rear cyl,for setting in traffic,is he FOS or is there a trick to it? if anyone is wondering tech is from Charlies HD in Huntington WV
RE: disable rear cyl???
It's in the '08 Touring Manual. At least it was for my new Road King Classic.
It appears under EITMS and looks like it is the "Parade Download" everyone has talked about for the '07's. I'm not sure if it is just on the touring bikes with Cruise, but here is what you have to do....
Turn ignition on, turn to "Run" but DO NOT START. At this point, roll the throttle forward and hold for three seconds and you will see the cruise light flash amber or green. I think green signifies parade mode (ie: Cylinder shut-off) and Amber signifies it's disabled (normal running). I may have those backwards though.
I messed with it the other day, it did help cool the engine, but NOTHING like my XiED's. Man, Nightrider has it going on, I can't believe the difference it has made. I have a pair of RJ's heat deflectors just sitting here waiting for me to put them on, but since the XiED's, I haven't wanted to take the time, because if I have any free time, it's putting miles on the bike.
here is a copy of the service bulletin you are looking for
https://www.hdforums.com/upfiles/45117/A4FC3962F1564DD6B2DB1D8E4B584707.jpg
