At highway speed, 70 to 85, i get a slight frotn end wobblle on my rk, checked tire pressure, its at 40, checked rear, its 42. its slight, not violent, but more then there should be, the bars wobble about 3/4 of an inch it seems. any idea??
Check the front and back tire for wear and tire pressure, Check the motor mounts, and make sure the front wheel bearings are in good shape. Had a buddy with the wobble and did everything till he replaced the front wheel bearings.
Have yer neck bearing checked. If you have ape bars look where yer arms are and the airrunning off them.
if you checked all that try cast aluminum wheels if you have spokes.
Try to think what was the last thing you did before the problem started too.
Hope one of these might help.
