E-Glide Primary Question
Old 06-02-2008, 08:24 AM
Road Head's Avatar
Road Head
Road Head is offline
Default E-Glide Primary Question
I did a little searching a found good info, but nothing touring specific. My problem is my Primary is leaking from the gasket, I figure it just needs replacing. Since the bike is "new" to me, I was going to let HD dealer do a 20K service, but they can't get to me for 2 weeks. In the mean time, my primary is roaring pretty good in turns and up or down hills. My guess is, it's low on fluid and not picking up enough in these conditions. While I wait, what type of fluid should I top it off with? Where is the best place to fill it? Thx!
Old 06-02-2008, 09:58 AM
Road Head's Avatar
Road Head
Default RE: E-Glide Primary Question
Looks like I may have asked a stupid question? [&:]
Old 06-02-2008, 10:03 AM
sf657's Avatar
sf657
sf657 is offline
Any 10-40 will work. Fill it thru the derby cover(the big round one) up to just above the bottom of the clutch. But you should pull the cover and check everything out. Like your chain tension and then put a new gasket on . You probably can do it yourself. If you haven't already, buy a service manual and that can be the last 60 bucks you have to give to the dealer. At the very least add some oil before you need a new clutch. They're not cheap.
Old 06-02-2008, 10:05 AM
sf657's Avatar
sf657
sf657 is offline
There are no stupid questions. And if there are, I asked them before you did.
Old 06-02-2008, 10:37 AM
Road Head's Avatar
Road Head
ORIGINAL: sf657
So the primary uses motor oil, not gear oil? There is a dipstick in front of the oil check, can you not add a little there?
Old 06-02-2008, 10:45 AM
mariner227's Avatar
mariner227
mariner227 is offline
The dipstick is for the trany, not the primary. There are three seperate places for oil. Engine, transmission, and primary. You can put 20 50 motor oil in all three. Check your manual .
Old 06-02-2008, 11:02 AM
Road Head's Avatar
Road Head
ORIGINAL: mariner227
This is more complicated than I thought. I've built entire Jeeps before with less confusion. Maybe I'm way off on what is actually make the "roaring" sound. It only roars in curves or on inclines and the bike has a noticable vibration. Level ground and lower temps its fine. Also the fluid leaking out doesn't smell like oil. Any ideas?
Old 06-02-2008, 11:11 AM
Neckball's Avatar
Neckball
Neckball is offline
No different from your Jeeps, really. Didn't they have a different fill location for the engine, transmission and differential fluids? Pretty much the same for your motorcycle.
Old 06-02-2008, 11:21 AM
sweet07's Avatar
sweet07
sweet07 is offline
You can buy your SM on eBay like I did. Save a few bucks. Pick up the gasket at the HD store and drain your primary, plug underneath the derby cover. Filler up with 38 oz 20-50 Amsoil and be done with it.
Old 06-04-2008, 10:47 AM
Road Head's Avatar
Road Head
Well it wasn't the primary. Primary is full, so I just retightened the bolts and it leaks no more. However, the sound, this "roaring" noise is still present. It sound likes its coming from the frontend and there is a vibration along with it. Any ideas? Wheel bearing, rotors warped....[&:]
Quick Reply: E-Glide Primary Question
