k&n air filter maintenance???
RE: k&n air filter maintenance???
ORIGINAL: Beemervet
50K is WAY too long to wait. 10-15K the filter is too dirty. You won't believe the dirt that comes off these things when the cleaner is sprayed on.
Never Replace Your Air Filter Again
Handmade in the USA and in the United Kingdom using only the finest materials, K&N OE Replacement Air Filters are washable and reusable. Regardless of what you’ve heard, it’s almost impossible to wash your K&N Air Filter too much. Inside our testing laboratory, we have washed and re-oiled one K&N Air Filter more than 100 times and it still performs up to specification. Depending on your driving conditions, we recommend cleaning your air filter every 50,000 miles. To clean and re-oil, purchase our filter Recharger® service kit and follow the easy instructions.
Check out the K&N website for the full scoop.
dude i bought my 06 ultra from put a stage 1 kit in it when he bought it. dealer tells me harley stage one kits come with k and n filters but the one on my bike says do not oil and it pretty much perfectly round. My 00 rk had the k nad noval filter. Have i got a k and n in the ultra?? It does hsya do not oil. Ideas??
50 IS WAY TOO LONG. I SPRAY THE CLEANER ON AND RUN WATER FROM THE INSIDE OUT TILL ITS CLEAN, SHOULD LOOK LIKE A GREY GYNM T-SHIRT. IF I HAVE TIME I LAY IT OUT IN THE SUN TO DRY, IF NOT A LITTLE BLOW FROM THE COMPRESSOR FROM THE INSIDE OUT TILL DRY AND THEN A LIGHT OILING
ORIGINAL: xcelr8
The people at K&N would dispute that. Remember, the key is to forget everything that "makes sense".
ORIGINAL: Beemervet
I have K&N's on every vehicle I own, including the Harley's. Cleaning a filters is easy, and in my mind as important as changing oil and filter. I'm not going to dispute any comments from K&N, but it'll be a frosty Friday in hell before I wait longer than 5K miles to clean any one filter. The biggest X-factor is your driving condition. Half an hour on a dusty dirt road and my filter will get cleaned before I drive the vehicle again, period. At worst, its peace of mind.
I've been using Simple Green on K & N filters for years with outstanding results, just spray on from the inside out and go pretty heavy with it, let stand for 15 minutes, rinse throughly but don't blast with hose sprayer, shake out excess water and set in front of a fan....done.
ORIGINAL: Truman
