Toe and Heel - Single Shifter Arm
Mornin' Guys. Thanks to all for the responses on the footwear. What's so great about this site is hearing "the tried and true" versions as opposed to the salesperson opinions.
Now for a question in regards to the "heel - toe" shifter levers.
Does anyone know of a single piece shifter lever that works well ona bagger (2003 Classic)?
Again, if you do, will you supply the "Where to purchase" information.
Much Appreciated.
Much Appreciated.
ORIGINAL: t059736
Much Appreciated.
Much Appreciated.
If you are wanting a heel, toe shifter that is one piece then you will have trouble as everyone likes to adjust theres to there fit.
If you are looking to go to a single shift arm, whatI do is take the heel shifter off and move the toe shifter out.Iusea chrome spacer that installs where your now black spacer is that has the additional length to take up the space where the second arm was. These spacers come with a wave washer to keep the assembly from rattling.
http://www.cvoharley.com/smf/index.php?topic=21256.0
Bottom right hand side is what looks like a 1 piece assembly.
http://www.masclassics.com/vtwin/0094.php
![](http://www.masclassics.com/vtwin/images/0094_50.gif)
As others have said. Just remove the back ( heal ) shifter...Harley makes the cap to cover the splines...Look at the fixed up models in the MoCo parts catalog, most have the heal shifter taken off! I did this upon getting mine home...personal preference more foot room to slide back and forth!
milo8155
07 FLHX
03 FXST
Colliervile,TN
milo8155
07 FLHX
03 FXST
Colliervile,TN
Try the New Way Shifter, www.newwayshifter.com. With this you remove your heal shifter and bolt on the new assembly so you now have two shift levers that all you do is push down to shift. The inside lever is for down shifting and the outside lever is for upshifting. Takes about 30 minutes to install and a few short rides to learn. Gives you more floorboard space and an easier way to shift.
