I have a 2007 RKC. Under the handle bar there are two switch, one is for the Aux lights and the second I was told is Aux plug for other use. Can someone help me identify the location of the plug? I want to use it for a second set of Aux lights. Thank you
I connected my GPS directly on the switch. Just unscrew the outside ring, then you can take the switch out ofit's socket (by the back) and then connect a cable on the switch.
Hope you ca understand, english is not my language....
