Oil Level and Temperature Dipstick with Lighted LCD Readout
RE: Oil Level and Temperature Dipstick with Lighted LCD Readout
Had a conversation with my HD parts manager and he said do not buy one, they have had 95% return rate on them. I did not ask what the problem was but he was very serious about it. I purchased the oil temp gauge that replaces the air temp gauge. Works great!
ORIGINAL: FLHT
I have had mine for about 2 years with no problems but I dont use a pressure washer and I dont use an air blaster to dry, I think this is where a lot of the problems come from.
ORIGINAL: 1hagop
ORIGINAL: madurodave
My problem was not using a presasure washer. I was caught in a downpour and the glass fogged over/battery died. The unit was returned. My second unit would not display oil level/temps correctly (jumped around). that did it for me. I need something that works, and not just in fair weather! It rains a lot here in NH!
ORIGINAL: FLHT
ORIGINAL: Johan96
Thanks for all the answers! I `ll guess I will pass!
ORIGINAL: Johan96
Is it hard to install?
ORIGINAL: 1hagop
ORIGINAL: captjon37
Most are getting them wet when washing the bike so as long as you only ride in sunshine with low humidity with it covered in plastic it should work great.
Mine has been working fine for 6 months. Been ridden in many hours of rain and sat outside in many a downpour.
It has also been washed (with a hose, no nozzle).
Had no problem with its' function so far.
HOWEVER, I would not buy another. I would take the extra time and money to mount one up on my handlebars so that I could read it easily while riding.
This is what I am going to do if this one takes a crap, and even if it does not, I will eventually get a handlebar mounted oil temp gauge.
I have one that was on the bike when I bought it. Have had no problems and bike has been washed with hard spray from a garden hose nozzle and also took a trip that included three days of torrential rain.
The negatives on it to me are that it shows error when you first shut down the engine and then I forget about checking it later after gassing up and it will show oil temp but not quantity when cold. Nothing wrong with it if it is already on the bike but I would not spend $135 for another one. But it does look nice.
