DYNO Numbers for Baggers???
Old 04-29-2023, 03:14 PM
ucbruce's Avatar
ucbruce
ucbruce is offline
Originally Posted by sick1
2019 RGU 114” Stage 2
S&S cam plate and oil pump (Fuel Moto)
Wood 22XE cam {Fuel Moto)
SE 5.5 injectors
SE 64mm intake manifold (stock 55mm throttle body as the SE was on back order at time of tune)
SE Ventilator Extreme
SE spark plugs and 10mm wires
Jackpot 2/1/2 head pipe (Fuel Moto)
SE 4.5” Street Cannons
Dynojet Power vision (Fuel Moto)
Should be even better when it flows more air...
The following 2 users liked this post by ucbruce:
sick1 (04-30-2023), Stu488 (05-02-2023)
  #6072
Old 05-02-2023, 01:24 PM
Stu488's Avatar
Stu488
Stu488 is offline
Stage I
2011 Ultra classic CVO 110 stage 2
110 max TQ at 4000 rpm
102 max HP at 6000 rpm
Feuling Reaper 594 cams
Vance and Hines big radius pipes
  #6073
Old 05-15-2023, 08:54 AM
hd king's Avatar
hd king
hd king is offline
2012 SG, 110" S&S drop on, Mega-Flo HVT/HO heads (1.730" port), 10.8:1, T-Man 625ps cams, HPI 58mm tb, Feuling 5.3 inj, Rush Wrath with 2.5" baffle, tuned with TTS by Jason Clasquin at C&S Speed Shop
The following 3 users liked this post by hd king:
rigidthumper (08-09-2023), sick1 (05-15-2023), Stu488 (05-15-2023)
  #6074
Old 06-15-2023, 05:23 PM
landiscarrier's Avatar
landiscarrier
landiscarrier is offline
2013 Ultra: S&S True Dual Head Pipe, Khrome Werks 4.5 Slip Ons with louvered baffles, SE 255 cam, Arlen Ness Big Sucker, Taylor 409 plug wires.
Tuned by JD Cycle Works in Nazareth Pa
  #6075
Old 06-16-2023, 12:35 PM
ucbruce's Avatar
ucbruce
ucbruce is offline
What else did you do? I get a little better numbers, but I have a full Stage IV kit. Heads, SE 259E cams, higher compression pistons, 59mm throttle body, and V&H Pro Pipe...
  #6076
Old 06-16-2023, 04:24 PM
landiscarrier
Honestly I’m not sure! Ha. I’m the 3rd owner and all I did was the exhaust and intake and then had it tuned. It ran ok…but was kinda rough, as the sheet shows. The previous owner didn’t do anything to it and had no idea what the original owner did.
  #6077
Old 06-18-2023, 06:26 AM
Sweep'r's Avatar
Sweep'r
Sweep'r is offline
Nothing that a good operator can't fix with the right equipment. Pushing a 16 ft-lb difference where the majority of everybody rides, 2500 rpm's and for those that still believe in no back pressure and an FP3...there's the results.
  #6078
Old 06-18-2023, 11:05 AM
landiscarrier
Yup. I told the tuner that I like the sound without the baffles. He said “do you want it to sound good or run good with usable power”. You can see my choice.
The following 2 users liked this post by landiscarrier:
Sweep'r (06-18-2023), ucbruce (08-24-2023)
  #6079
Old 08-08-2023, 02:02 PM
ScottyG1616's Avatar
ScottyG1616
ScottyG1616 is offline
Stage II
Smile 112 HP and 120 Torque
Bumped my 2009 Street Glide up to an S&S 110" kit, added Mackie 575 cams, a tuner, and Bassani 2-i exhaust. My bike ***** and gets now! Dyno sheet is attached.
  #6080
Old 09-14-2023, 06:24 PM
Bgill's Avatar
Bgill
Bgill is offline
The following 2 users liked this post by Bgill:
Harley1004 (09-14-2023), sick1 (11-20-2023)
Quick Reply: DYNO Numbers for Baggers???
