DYNO Numbers for Baggers???
#5902
My FM 128 2017 CVO Limited. For details on the build you can read about it here https://www.hdforums.com/forum/milwa...xperience.html
Stud Duck (02-25-2020)
#5903
Just yesterday picked up my '16 FHTK from HD Forum sponsor Hillside Machine & Motorcycle. After talking with owner Scott Palmer, I ended up with an S&S 110" kit with Bob Woods TW-6-6- cams & Hillsides magically reworked heads. I wasn't looking for top H.P. , but a reliable, torquey touring motor. Now he also sez my mpg might stay the same or go up 1-2 mpg. Seriously?!? Not with me twisting the throttle all the time!
It too bad that winter is here! I can't wait to ride this bad boy! Here's my Dyno sheet if anybody cares:
#5904
Scott Palmer at Hillside would be the one to ask. I’ve got just under 200-miles since I picked it up. It’s SWEET!
#5906
Received 6,620 Likes
lightweight bob (03-14-2020)
#5908
I spent a couple months researching my build, with the help of a great friend Joe. I also spoke several times with Don at HD Street performance. I also followed Darens posts on his step by step build with the CR-482. I was suprized by the power it makes, Brandon the tuner was also.
My build is: 2019 FLTRXSE
S&S black granite cylinders, punched for 130 by Don
Mahle pistons for 130, coated by Line to Line
Heads done by Don at HD Street Performance set for a 12.1 to 1 with a zero deck height.
HPI 62 throttle body and intake with 6.1 injectors
SE adjustable rockers
SE adjustable push rods
CR-482 Cam
2020 HD 8 lobe oil pump
S&S lifter cuffs
HD extreme Heavy Breather
Recluse Torque drive clutch
Fullsac Head Pipe and 2.25 baffles with tech mat and screens.
CR-482 Cam
S&S lifter cuffs
The following 3 users liked this post by FLSTFI Dave:
#5909
CR-482 Cam
S&S lifter cuffs
CR-482 Cam
S&S lifter cuffs
FLSTFI Dave (04-03-2020)
#5910
i spent a couple months researching my build, with the help of a great friend joe. I also spoke several times with don at hd street performance. I also followed darens posts on his step by step build with the cr-482. I was suprized by the power it makes, brandon the tuner was also.
my build is: 2019 fltrxse
s&s black granite cylinders, punched for 130 by don
mahle pistons for 130, coated by line to line
heads done by don at hd street performance set for a 12.1 to 1 with a zero deck height.
hpi 62 throttle body and intake with 6.1 injectors
se adjustable rockers
se adjustable push rods
cr-482 cam
2020 hd 8 lobe oil pump
s&s lifter cuffs
hd extreme heavy breather
recluse torque drive clutch
fullsac head pipe and 2.25 baffles with tech mat and screens.
cr-482 cam
s&s lifter cuffs
The following 2 users liked this post by QNman:
FLSTFI Dave (04-03-2020),
rockymtman (04-02-2020)
