DYNO Numbers for Baggers???
Old 05-07-2015, 05:33 PM
oldhippie's Avatar
oldhippie
oldhippie is offline
Originally Posted by Kingsglide103
2011 103" Street Glide
Andrews 57H
V&H Pro Pipe Chrome
SE Agitator A/C
SE Lifters
Stock Pushrods
SEPRT
That's a nice chart you got there.
  #4962
Old 05-07-2015, 05:42 PM
oldhippie's Avatar
oldhippie
Originally Posted by davidw221
Had my bike dyno'd last week I have a Thundermax, level B heads, TW-8-6 cams, SE extreme AC, Rinehart true duals, 107 10.5 pistons, only got 92HP, with 111tq. The Thundermax tech was there and put my bike on his computer for over an hour, changing different settings, when it was all done he showed me graphs where my issue with my bike was starving for air. Dyno guy also stated my bike had a stock Throttle body, with my setup, my heads were starving for air, then he explained that the stock throttlebody measured only get 31MM of air through a 50MM Throttlebody, suggested a HPI which gets 58-55MM to each head, he measured a stock Throttlbody, and he was right, air is king. Next week I'm going to purchase a HPI Throttlebody, and put it in. Folks that I know who have had top end work done stated this is a must.
The Thundermax Tech stated, my injectors were marginal according to the graphs.
It's all about air flow, and the weakest link in the chain is what will limit you.
When I had my FM 2007 EGC 107" build done with Level B heads, Fuel Moto suggested going with the SE 50MM with 49MM injectors, which they found did a good job matched for the 107/heads build. Rinehart true duals should provide plenty of flow. You'll realize another 10/10 or more I'll bet.
  #4963
Old 05-08-2015, 05:29 AM
sporacer's Avatar
sporacer
sporacer is offline
There are a ton of 107 kits out there with a stock 50 mm tb making much better numbers. Your true duals are hurting you a bit on the bottom end but ill bet youll find your answer is in your tune.
  #4964
Old 05-08-2015, 06:44 AM
harleytuner's Avatar
harleytuner
harleytuner is offline
I'd like to see the graph before making the assumption on the tune. There's a good chance it's in the tune, but it could be timing off, sumping or a number of things.
  #4965
Old 05-08-2015, 10:13 AM
sporacer's Avatar
sporacer
sporacer is offline
Good point but I was assuming ccp test was already done to verify when the engine was assembled.
  #4966
Old 05-08-2015, 11:21 AM
harleytuner
ccp won't show sumping though.
  #4967
Old 05-10-2015, 06:14 PM
davidw221's Avatar
davidw221
davidw221 is offline
I'm looking for the graph, I was so disappointed in the number after my tune I don't know what I did with it.
My bike was on the dyno for at least 45 minutes, then the TMax tech spent another hour and a half adjusting things, and uploaded the newest firmwares.
One thing they told me was to take them damn SE spark plugs and replaced them with stock ones, they said those cause RF interference, what ever that is.
I still haven't purchased my HPI, going to do that purchase this coming Friday.
  #4968
Old 05-11-2015, 05:09 AM
sporacer's Avatar
sporacer
sporacer is offline
It looks like your Tmax tech was trying to find something to blame for your less than stellar results. Ive used SE plugs in many builds and never had an issue with rf. The first thing id be doing is ditching the Tmax.
  #4969
Old 05-11-2015, 05:24 AM
Tn.Heritage's Avatar
Tn.Heritage
Tn.Heritage is offline
Don't get me wrong here because I'm not a fan at all on the T'Max's so I'm not supporting them but ease over on HTT forum and mention SE Plugs or other's that are similar and you will get the same response as the T'Max did.
Also seems even those guy's can't tune one of there products either. It's all in the tune if it's not sumping.
  #4970
Old 05-11-2015, 11:22 AM
harleytuner
The issue with the SE plugs is the interference with the spark pickups we get on the dyno. The RPM's cut in and out when we are sampling. I usually just throw a set of regular plugs in for the tune then swap them back out after the tune. There are some other issues that i've heard about that come into play when people street tune, but since I don't get into street tuning or any of that I won't elaborate because I only know what i've heard and don't have any direct knowledge with it.
Quick Reply: DYNO Numbers for Baggers???
