DYNO Numbers for Baggers???
Old 06-15-2006, 09:02 PM
jeepster09's Avatar
jeepster09
jeepster09 is offline
Received 7,733 Likes on 1,260 Posts
Default RE: DYNO Numbers for Baggers???
Re-tuned and tweaked FLHTI 2005
NOW I'M SMILIN!!!
Torque comes on at 2500 and goes right to 100. Flat torque line right accross till torque peaks at 108.25. Horsepower then hitts 80 at 4000 rpm and continues climbing to 121.41 at 6000 rpm.
[sm=happybounce.gif]
[IMG]local://upfiles/1346/BB428C9FEB9F425D879B0248CE002042.jpg[/IMG]
  #172
Old 06-16-2006, 08:22 AM
cdn.biker's Avatar
cdn.biker
cdn.biker is offline
Jeepster09,
Awsome numbers for a 95 incher. Must feel like a rocket. Congrats.
Tom
  #173
Old 06-16-2006, 10:05 AM
jeepster09's Avatar
jeepster09
It does; It's nice to finally get the right combo after all the iniatial misdirection from the so called experts. Whats also nice is all this power and it stilll starts good and uses standard premium pump gas with no additives and no pinging.
  #174
Old 06-16-2006, 11:54 AM
PanHeadRed's Avatar
PanHeadRed
PanHeadRed is offline
Stage III
jeepster, can you provide more info on the build using the Andrews TW-31. Is the Dyno available to post? It sounds like you were running it @ 10.0:1 or so compression.
Thanks,
PHR
  #175
Old 06-16-2006, 12:05 PM
PanHeadRed's Avatar
PanHeadRed
Stage III
Bigzed, don't be so quick to blame the came. the S&S 510 is a nice one.
PHR
[IMG]local://upfiles/13751/6BEB2B89271349BC9AA518D993F85A7A.jpg[/IMG]
  #176
Old 06-16-2006, 12:23 PM
PhilM's Avatar
PhilM
PhilM is offline
ORIGINAL: PanHeadRed
PHR
PHR,
Is the graph you posted a build w/510's (tuned by Dean)? It has nice peak torque #'s, but as with most 510 builds it does not come on "strong" until 3k+. Also curious what else is in that build...????....
Phil
  #177
Old 06-16-2006, 03:31 PM
PanHeadRed's Avatar
PanHeadRed
Stage III
Phil, it is not my bike so I am not sure who did the tune. What I do know is:
95" @9.3:1
Heads
Rinehart Duals
  #178
Old 06-16-2006, 03:43 PM
Biggzed's Avatar
Biggzed
Biggzed is offline
PHR
PHR - Not quite sure when or why I blamed the 510's???? Nice graph, I bet that bike is a blast to ride.
BZ
  #179
Old 06-16-2006, 11:12 PM
gasman's Avatar
gasman
gasman is offline
Just had my 03 Screaming Eagle Road king Re-mapped with a custom map by Eastern Performance who installed my Rineharts, PC111 and big sucker a/c and originally mapped it in Oct. 05. Was popping and carrying on.
Fowled plug and running a little lean. Matt the tuner said he could lift the front wheels off the ground when he hit second after the custom map.
Runs great now
102.1 HP
104.2 ft/lb torque
AFR 13.6
  #180
Old 06-17-2006, 08:16 PM
jeepster09's Avatar
jeepster09
Thanks,
PHR
My build:
Kuryakken 26G cam
Andrews gear drive
Overflow air filter
Kuryakken forged hi-comp pistons at 10.44 to 1 comperssion ratio
95"
Stock heads ported by Bob Wright at R&D Performance
Kuryakken 57 mm throttle body
S.E. Race Tuner
Runs on 91 octane gas w/ no pinging at any rpm
Super Trapp 2 into 1 exhaust
VPC clutch plate with S.E. spring
I used R&D Performance and World Class Tuning in Watertown MN. I should of went here first and save alot of money! These guys are awesome! Many thanks to Bob Wright and Mike Rolland.
Quick Reply: DYNO Numbers for Baggers???
