DYNO Numbers for Baggers???
#151
RE: DYNO Numbers for Baggers???
ORIGINAL: PipeDADDY
I just got my bike back from the Sabine Performance DYNO shop in Dallas (http://sabinperformance.com) and BOY-O-BOY I couldn't be happier. This is soooooo much better than I expected.
MY GOAL:
Low end TQ on a BUDGET.
Here are my MODS:
2005 FLTRI
95" TC; SE Flat Top Pistons
Arlen Ness Big Sucker
D&D 2.5" slip-ons
Andrews TW26a Cams
PCIII USB (w/ Rev extender)
Stock ECM
Stock Heads
Stock Rods
RESULTS:
98.1 TQ
81.8 HP
Did I do good or WHAT??? (er....I mean with PhilM's help of course ) The thing that I noticed most is my 2.5k to 3k RPM range. I enter 90 about 2750 and I hit mid 90s about 3k. I think I reached my goal of low end TQ on a budget!
MAP LEGEND
Green is baseline with Big Sucker, D&D exhaust, and PCIII only! generic MAP; 88"; stock Cams
Red is pre-tuned generic MAP for 95" and TW26a cams
Blue is post-tuned custom MAP with above specs (After DYNO)
MY GOAL:
Here are my MODS:
2005 FLTRI
D&D 2.5" slip-ons
Andrews TW26a Cams
Stock ECM
Stock Heads
Stock Rods
RESULTS:
98.1 TQ
81.8 HP
MAP LEGEND
Wait until you do the heads, then you will crap your pants.
#153
HP = 88.43
TQ = 91.63
I put the pipes, air cleaner, and PC on myself last summer. Had the engine work done during the xmas break and used my tax refund to pay for it. Had it done by the local HD dealer. Don't care much for the dealership as a whole, but I do like and trust the service manager and the mechanics. They used a map they downloaded from PC that was close but had a Woods cam. They didn't want to do the dyno 'til I broke it in again. It had a big hole in the 2400-2900 RPM range, then it would break your neck. I got a lot of it out but finally got the dyno tune done last week (3,000 miles later). Sweet! I'm tickled with the power and the smoothness of the curves. It's a real joy to ride now. I was hoping for 90 HP and didn't miss by much. I've never had a flash or bumped the rev limiter, but based on the curves, if I did, I probably would have gotten the 90 HP out of it. I don't see the need on a bagger though.
I'm adding an oil cooler as soon as it arrives. Next xmas, I'm probably going to invest my tax return in a 6 speed and maybe a set of gear driven andrews cams.
OK. Let's see if I can remember the parts:
2005 FLHTCUI
Bassani Road Rage 2:1 in Black
Power Commander III USB
Arlen Ness Billet Sucker Stage II Air Cleaner
SE Big Bore Cylinders - 16546-99
SE Performance Heads - 16952-99b
SE High Compression Cast Pistons - 22661-99a
SE-204 Cam Kit - 25149-00
SE-Perfect Fit Pushrods - 18403-03
SE Compression Releases - 29298-02
[IMG]local://upfiles/3024/8501A4BB70FE497087E99925791AF618.jpg[/IMG]
TQ = 91.63
2005 FLHTCUI
#155
ORIGINAL: cherrydresser
got dyno run today
78.0 H.P and 89.1 max torque
2005 ultra
95 C.I. kit
203 cams
PCIII commander
stage II flash
rinehart trueduals
[IMG]local://upfiles/10555/D57DCE7C84094E6CB60B18A9E7FA16E9.jpg[/IMG]
got dyno run today
2005 ultra
95 C.I. kit
203 cams
PCIII commander
stage II flash
rinehart trueduals
Interesting......
I have an '03 Ultra
95"
203 Cams
SERT
SE slip-ons
79.8HP and 99.8 Tq
I guess that confirms that dyno numbers are just a general reference..........
#156
ORIGINAL: gearheadfmc
Interesting......
I have an '03 Ultra
95"
203 Cams
SERT
SE slip-ons
79.8HP and 99.8 Tq
got dyno run today
2005 ultra
95 C.I. kit
203 cams
PCIII commander
stage II flash
rinehart trueduals
got dyno run today
2005 ultra
95 C.I. kit
203 cams
PCIII commander
stage II flash
rinehart trueduals
Interesting......
I have an '03 Ultra
95"
203 Cams
SERT
SE slip-ons
79.8HP and 99.8 Tq
#157
Okay.....What is the reason the '05 heads are different or more restrictive than previous versions? Some sort of smog law crap or?
I was under the impression -- maybe wrong -- that the '06 heads were changed and more restrictive.
I guess I'll investigate.
I just sent a set of heads out for porting -- should get a 30% increase in flow. I expect to have at least a square....100/100 min.
#158
#159
