DYNO Numbers for Baggers???
Old 06-03-2009, 06:55 PM
imrotton2's Avatar
imrotton2
imrotton2 is offline
Originally Posted by Lost Lake
2001 Ultra, 95", 203 cams, SERT, Jackpot mufflers
85.6 HP / 99.6 Torque
Still looking for an extra .4 torque to make that magic 100 number!
a 2/1 pro pipe would put you over 100 easy, i would think
  #1192
Old 06-03-2009, 06:59 PM
HDUltraRider's Avatar
HDUltraRider
HDUltraRider is offline
O7 Ultra Classic SERT, Vance Hines True Duals with Monster oval .
HP 70.76 and Torque 83.91
Is that low?
  #1193
Old 06-04-2009, 08:25 PM
dpoteete's Avatar
dpoteete
dpoteete is offline
Stage I
Default 09 streetglide
103 Kit with Lozano bore matched cylinders, 211 SE cam, dynojet PC 3 usb, Mike Lozano ported polished heads w/ compression releases, 10.5 comp SE pistons, V&H 2 into 1 propipe, SE clutch, stage 2 air set up w/ K&N.
Dyno tuned by Lozano @ 98.5 HP 102FT lbs torque
  #1194
Old 06-06-2009, 01:45 PM
Fast FLHX's Avatar
Fast FLHX
Fast FLHX is offline
Should be getting a dyno tune next weekend. Going to be adding P&P heads and 10.5 comp pistons.
Hoping for 100/1xx but will be happy with 9x/1xx
  #1195
Old 06-06-2009, 02:19 PM
HDWRENCH's Avatar
HDWRENCH
HDWRENCH is offline
Default RK 100 new 117
Posting this up for him as he is still working out how to get a sheet loaded. His old engine spit the crank out so we bumped it up to a 117.
Specs
GMR 117 build'
Axtell cylinders
10.5 compression
R&R 615/585 cam
HPI 51 T/B
R&R cast heads
fat cat with perf big bore baffle
Attached Thumbnails  DYNO Numbers for Baggers???-dj-gmr117-10.5-cast-fc-perf-bf-hpi-51-615.jpg
  #1196
Old 06-07-2009, 05:41 PM
digz`'s Avatar
digz`
digz` is offline
Stage II 103"
255 cams
Rinehart Slip-ons
SE Heavy Breather
  #1197
Old 06-08-2009, 10:58 AM
capbenedict's Avatar
capbenedict
capbenedict is offline
DIGZ, what header are you running (stock 48 state or CA, aftermarket, etc.) and what MAP did you install. I have the same install with the 103 MAP. I have the 48 state stock headers with Supertrap SEs. Sometimes I think my HP tops out to quick but the bottom end is great.
  #1198
Old 06-09-2009, 01:31 AM
digz`'s Avatar
digz`
digz` is offline
Stock head pipe with Rinehart slip-ons.
If you look at my attachment thats the before and after with 103map from HD and after with custom map. It made a world of difference ... like a new bike
  #1199
Old 06-09-2009, 12:04 PM
capbenedict
Digz, thanks for the info. I'll give them a call and see if they can help me from affar. I'm about 1300 miles from Richardson, TX. Maybe it's time for a road trip!
  #1200
Old 06-09-2009, 10:10 PM
CDP1911's Avatar
CDP1911
CDP1911 is offline
Headquarters ST107 Top End kig
Diamond Cut Heads and Cylinders
SE Premium Adjustable Push Rods
Stock Throttle body and injectors
Doherty Machine Power Paac
D&D Fat Cat 2:1 Standard Baffel with ghost pipe
AIM 92T VPC
SE Clutch Spring
Build by PhilM (This **** is amazing)
SERT Tuned at the Dyno Difference (This **** is also amazing)
HP = 113 Torque = 126 Engine runs smooth Mileage is over 40 MPG Horse power and torque kick in around 1900 and pulls and pulls and pulls for freak'n ever
Quick Reply: DYNO Numbers for Baggers???
