DYNO Numbers for Baggers???
#1091
dyno numbers for my '07 Road King Classic
SE air cleaner
SE race tuner
Bassani slip-ons
stock 96" motor
SAE corrected on a SuperFlow WinDyn
82 hp and 98 ft lbs
I have dyno sheet. will post it as soon as i figure out this new scanner!
All the tuning was done at Skip's Cycles in Winchester, VA
SE race tuner
Bassani slip-ons
stock 96" motor
82 hp and 98 ft lbs
#1092
dyno numbers
Just installed 103 kit on my 2007 flhr road king. Dyno base line 67 hp 70 ft/lbs torque after install se cylinders,flat top pistons,255 cams,heavy duty clutch spring,rinehart tru duals,se high flow air cleaner,se race tuner,95 hp and 98 ft/lbs torque some difference huh and it also sounds and runs great
#1093
WOW if those numbers are true for a basically stock motor...just hope the tuner wasn't doctorin' the numbers :-)
#1094
#1096
bagger numbers
This is my build
04 FLHTC 88ci
Andrews TW-37 cams (still chain drive )
Ness Big Sucker 1 A/C
Russ Slip Ons 2-1/4 Baffles
Heads Milled .30 ( w/stock valves ) ported
Stock A/C Cover Modifed On Bottom
48 Pilot
190 Main
Max Power= 78.1
Max Torque= 91.6
Bike Runs Strong Avg 42 MPG
Bike Run On Dynojet 250 Dyno
04 FLHTC 88ci
48 Pilot
190 Main
Max Power= 78.1
Max Torque= 91.6
#1098
08 ultra. SERT, Stage 1, V&H true dual, slash cuts.
Max Power 68.84
Max Torque 86.62
My figures dont appear to be very similar to others, I seem to have lower power but higher torque, I can only assume figures are accurate, tuning was done by Calgary H,D
Hope chart scan works
Max Power 68.84
Max Torque 86.62
#1099
Max Power 68.84
Max Torque 86.62
Max Power 68.84
Max Torque 86.62
just my 2 cents
Bandit
