Cruise Control - Possessed!!!!!
Something is f'ed up with my cruise control. I set it and - on its own - it slowly increases speed 20+ mph!!! I tap the brakes, front and/or rear to disengage and it doesn't disengage. I shut off the power (toggle switch on dash) to the cruise and it still stays on. I can get it to disengage by blipping the throttle a few times. Any ideas on what the problem could be?
Thanks for the help,
RJ
RJ
RE: Cruise Control - Possessed!!!!!
Had a hard time to get mine to release. I took it to the dealer and talked to thetech He said that the throttle cables on bike with cruse are a little more sensitive for some reason
Took him about 3 min to fix no charge never had a problem till we gotcaught in a bad down pour on hot day guess cable shrunk a little no problem now
RJ: Here's a link to the DIY part of the Forum that gives the HD Electrical Diagnostic Manual's procedure for using codes to determine problems with cruise control.
https://www.hdforums.com/m_104421/tm.htm
From what you described, "possessed" is an accurate description--hope you get it figured out.
