RKC front brake pulse
My 05 RKC has developed a pulsing when applying the front brake.
Aside from warped rotors, what could I look for as a reason? Pads are OK, only 10K on the bike.
If I need to replace the rotors, what recommendations do you have for new ones? Full floating? or the HD almost full? or? Drag Specialties has some that seem like they would do the job and they look good too, any other sources to consider?
Would like to try this install mtself so would appreciate any tips on doing the work. Was told the 5 bolts per rotor are one use only and I will need 10 new ones. Is that correct?
