PCIII, DFO???
PCIII, DFO???
I currently have the Stage 1 kit with the SE Slash-down pipes. I have a set of Thunderheaders (2-1) on order, should get them by the time I get back from my trip this week (Friday).
Do I need to change anything after setting up the T'header? Can I run it like with the current settings until I decide what to do?
I'm contemplating a Power Commander, DFO, or SERT, which do people think would be better? (I'm sure that's going to open a can of worms!)
RE: PCIII, DFO???
I would guess the majority of people are going to go tell you to go with the SERT. I do not have experience with it but I do have a PCIII. I installed it myself, downloaded the map from the web site and really like the results. I will probably get it dyno tuned this summer. I really like the ease of the PCIII and I like working on my own bike.
RE: PCIII, DFO???
Screaming Eagle Race Tuner is exactly what it says....it's a race tuner. If your motor is stock, except for the breather and pipes...then I would go with the PCIII. I have the PCIII on my Ultra and it's got all the maps available for almost every combo of parts and breathers. If you add parts later....you can just upload a new map and your done.
Good luck.
Shop the internet....you can find some good deals on the PCIII.
Good luck.
RE: PCIII, DFO???
ORIGINAL: luvmyflhtcui
Good luck.
Good luck.
I haven't really heard anything all that great about the Fuel Pak, tda. If I knew more about it maybe I would add that as a consideration though.
So do I need to have the PCIII (or whatever I choose) before I take my bike out for a ride with the Thunderheaders installed and the current Stage I?
