Wheel Bearing Size
Wheel Bearing Size
Anyone know if Ness Wheels 21" front and 18" rear... Will be the same size as Factory wheels on a Street Glide ???
Had My Wheels Powder coated and the Guy didn't Press the Bearings all the way in, And the Spacer ate them Up [:@]
Now It's Memorial weekend, Nice weather, And I can't ride unless I find Bearings,, Just looking for some input, So I know what Direction to go in the Morning ..
RE: Wheel Bearing Size
The best source of information on the axle size/bearing size of an aftermarket wheel would be the manufacturer/distributor of the wheel wouldn't it? Don't you order aftermarket wheels by telling the vendor what bike the wheels are going on, and the wheel is intended to be a direct replacement--with rotors that will work with your calipers, etc.?????
ORIGINAL: Harleypingman
I know the ID on the Bearings are the Same, But Not Sure about the OD
I agree with Harleypingman,....Why not ask the manufacturer? You should be ordering wheels for the model and year of the bike you have. The manufacturer should be providing the correct wheel to fit what you have--they have to keep up with the changes or their products wouldn't sell.
You still haven't even told us what year bike you have. There is very distinct verbage in the Harley catalogs that the '08 wheels only fit '08 models. Not only were bearings changed, but they also went to Brembo brakes on the '08's.
ORIGINAL: uweldit
I guess I'm wondering how an aluminum axle spacer ate a bearing?
Did you put the spacers in the right place? --sorry don't know your level of expertise.
Turns out that the Powdercoater PRESSED them out and thenPressed them back in, Screwed them up pretty bad ,23 miles and the wheel was growling....
07 street glide 1" axle
Talldog
07-31-2013 10:22 AM
