Shorty Antennae for Ultra Classic
Old 05-23-2008, 01:19 PM
Crazier Steve's Avatar
Crazier Steve
Crazier Steve is offline
Default Shorty Antennae for Ultra Classic
Hey Guys,
Do the shorty antennae for the Ultra Classic work well. I have to bend my current antennae down every time I put my bike in the garage. It's starting to be a pain. Does your CB and radio work just as well as with the stock antennae? If so, which brand would you recommend. This forum is great. I always appreciate the info I get on here. Ride safe but ride as often as you can! Crazier Steve
Old 05-23-2008, 01:35 PM
Coffee's Avatar
Coffee
Coffee is offline
Default RE: Shorty Antennae for Ultra Classic
I went to Kragen and got a standard rubber replacement shorty antenna for mine. No difference in reception at all. Don't have the CB though, so I can't help you there.
Old 05-23-2008, 01:57 PM
troutbum1971's Avatar
troutbum1971
troutbum1971 is offline
i got the j&m
Old 05-23-2008, 02:37 PM
alqaadir's Avatar
alqaadir
alqaadir is offline
Yes,I got mine from eglidegoodies.com
Old 05-23-2008, 02:46 PM
WI George's Avatar
WI George
WI George is offline
6th Gear
Got the J&M shorties, work very well - radio & CB. Only problem I run into is that the screws keep stripping out as I remove them every winter since I cover the bike. (The holes, not the screws). When I first bought them one of the screws would not even screw in but J&M sent me a replacement right away. Guess I will have to try a slightly larger screw if I want them to hold from now on. This is the only irritant for me as they do work very well!
Old 05-23-2008, 02:53 PM
WildHair's Avatar
WildHair
WildHair is offline
I have the J&M ones too. Work great on the am/fm. I do not use the cb so can't comment on that.
http://www.jmcorp.com/ProductDetail....P-ATM&PF=6
Old 05-23-2008, 02:56 PM
Bluzmn59's Avatar
Bluzmn59
Bluzmn59 is offline
J&M - work equally well on the radio and CB.
Old 05-23-2008, 03:05 PM
katobird's Avatar
katobird
katobird is offline
5 BUCKS, LITTLE SHORT ANTENNA FROM YOUR LOCAL AUTO PARTS STORE
THREADS ARE THE SAME
WORKS GREAT
Old 05-23-2008, 03:51 PM
Buzzsaw's Avatar
Buzzsaw
Buzzsaw is offline
I had a set of cheap rubber shorties they worked fine for the AM/FM, but the CB lacked range, I just picked up a set of J&M from Eastern's today. They seem to work real well.
Scott
2007 EGC
IDS
Old 05-23-2008, 04:27 PM
jtfisc2's Avatar
jtfisc2
jtfisc2 is offline
6th Gear
Yep, got mine at Auto Zone (5 bucks)and they work fine for both Radio and CB?Intercom. Put a little blue locktight though as they will rattle off.
Quick Reply: Shorty Antennae for Ultra Classic
