Shorty Antennae for Ultra Classic
RE: Shorty Antennae for Ultra Classic
J&M antenna's cost more....but they're built to conform to the operational requirements of a CB antenna. The cheapies are just that - built cheap, they are NOT set up to operate a CB properly, and unless yer REAL lucky you CAN burn out the finals in the CB usin' 'em. Ah've run CB's since the 70's, an' used ta participate in contests ta see who could run the longest "skip" without boots - an' usually won, so yeah - ah unnerstand a tad 'bout 'em. Those that say "no difference" - ah'm sorry, but there IS a difference, an' one that is measurable - even w/the J&M shorties over the OEM. It's a function of the shorter antenna, an' nuthin' you kin do can change that. Use the cheapies at yer own risk - but KNOW that if ya toast yer CB, the MoCo is gonna deny the claim when they see the burned finals.
ORIGINAL: WI George
Got the J&M shorties, work very well - radio & CB. Only problem I run into is that the screws keep stripping out as I remove them every winter since I cover the bike. (The holes, not the screws). When I first bought them one of the screws would not even screw in but J&M sent me a replacement right away. Guess I will have to try a slightly larger screw if I want them to hold from now on. This is the only irritant for me as they do work very well!
